AutoCAD Structural Detailing General
Active Contributor
maronas
Message 1 of 3 (403 Views)
Accepted Solution
ASD2011 round profiles
403 Views, 2 Replies
06-27-2011 11:34 PM
Hello, guys, im in need of serious help.
Im designing a steel chimney, and cant get round profiles to be "round"
Im adding custom round profile Ø1500x14mm, and it always displays as 16-sided polygon. Is there a way to increase round profile's smoothness in ASD? I've tried all autocad option relating to this, no luck.
Thanks.
Product Support
pp2008
Message 2 of 3 (389 Views)
Re: ASD2011 round profiles
06-28-2011 02:15 AM in reply to: maronas
you can use the following commands:
Command: profslices
Select objects: all
Profile slices is 16
Enter new profile slices <16> :64 (value that can be divided by 4)
and in case of cuts between objects
Command: cutslices
Select objects: all
Cutting slices is 32
Enter new cutting slices <32> :128 (value that can be divided by 4)
Best regards,
Pawel Pulak
Active Contributor
maronas
Message 3 of 3 (386 Views)
06-28-2011 03:21 AM in reply to: pp2008
Thank You, Pawel, its smooth as silk now :smileyhappy:
Now thats what i call tech support, keep up the good work!
You are not logged in.
Announcements
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
