AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
ASD2011 round profiles
2 REPLIES 2
maronas
816 Views, 2 Replies
Hello, guys, im in need of serious help.
Im designing a steel chimney, and cant get round profiles to be "round"
Im adding custom round profile Ø1500x14mm, and it always displays as 16-sided polygon. Is there a way to increase round profile's smoothness in ASD? I've tried all autocad option relating to this, no luck.
Thanks.
2 REPLIES 2
Pawel.Pulak
in reply to: maronas
you can use the following commands:
Command: profslices
Select objects: all
Profile slices is 16
Enter new profile slices <16> :64 (value that can be divided by 4)
and in case of cuts between objects
Command: cutslices
Select objects: all
Cutting slices is 32
Enter new cutting slices <32> :128 (value that can be divided by 4)
Best regards,
Pawel Pulak
Technical Account Specialist
maronas
in reply to: Pawel.Pulak
Thank You, Pawel, its smooth as silk now 🙂
Now thats what i call tech support, keep up the good work!
”Boost
”Tips
