• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Active Contributor
    ASD2010-Reinforcement Module New Fatal Errors after asd_2010_hf5_32bit
    216 Views, 0 Replies
    01-30-2010 05:50 AM
    asd_2010_hf5_32bit has solved the most repeated fatal errors (at least 99%), however there are some new fatal errors come during the surface distribution option in the following cases:
    a) after adding a leg segment in Reinforcement - definition and detailing / Shape definition dialog where you can select a geometry of bar end.
    b) just before the appearance of the Description of reinforcement distribution.
    c) when adding a reinforcement (reinforcing bar) to an existing element through the Element manager.
    d) when creating a section to existing element containing reinforcement.
    e) when changing the existing section (of element containing reinforcement) cut line location.
    1- FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 30e368b9h
    2- FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 2f2568b9h
    3- FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 300168b9h
    4- FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 318b68b9h
    5- FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 6b268b9h
    6- FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 1e441cfch
    7- FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 1e451cfch
    8- FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 1e551cfch
    There is a clear relation among the above errors:
    Unhandled Access Violation Reading 0x0000 Exception at ****68b9h
    Unhandled Access Violation Reading 0x0000 Exception at 1e**1cfch
    Edited by: abbakeer on Jan 31, 2010 11:40 AM
    Please use plain text.
