These errors are back even after the updating: ASD 2010 SP1 and hotfix2
FATAL ERROR: Unhandled Access Violation Reading 0x03b8 Exception at 17e232edh
FATAL ERROR: Unhandled Access Violation Reading 0x3d688a38 Exception at 41703eh
FATAL ERROR: Unhandled c0000417h Exception at 7858c955h
FATAL ERROR: Unhandled e06d7363h Exception at 7c812aebh
Please find below how this type of error occurs in terms of Q and A:
Q: what option do you use?
A: Reinforcement module, most of modification options.
Q: what version of ASD do you use?
A: ASD 2010
Q: what are your computer parameters?
A: Pentium(R) D CPU 3.40GHz
3.39 GHz, 3.24 GB of RAM
Physical Address Extension (The actual RAM is 5 GB)
Q: Please give a scenario to get Fatal Error
A: All the fatal errors are coming when the modification is in progress.
For example, if you want to change the "user description" with another value not shown in the related drop down menu. Also when changing the spacing between existing bars distribution pattern.
The most repeated error is:
