AutoCAD Structural Detailing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
ASD reinforcem ent 2013 - insert drawing from ROBOT 2013 not working
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have RSA pro 2013 Sp2 and ASD 2013.
I have robot file with rc column reinforcement drawing.
When I try to "insert drawing from Robot" it gives me te following error: Error load type library / DLL.
I have tried this on two different PCs.
Any suggestions?
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Re: ASD reinforcem ent - insert drawing from ROBOT not working
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The situation is:
Both Robot and ASD 2012 and 2013 are installed.
Robot 2012 is then uninstalled.
Reported problem:
It is no longer possible to open RC drawings created in Robot 2013 in ASD 2013.
Solution:
It is necessary to manually delete the following registry key:
[HKEY_CLASSES_ROOT\TypeLib\{1517EFF1-9EC2-11D4-B22
Mind that that key has to remain:
Reason:
Uninstalling of Robot 2012 leaves the excessive registry key which should be reased during this process
Priit:
Please confirm that the above solution solved this issue. Thank you.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have more than one PC, so I made a reg file to make it easier. Enjoy.
