• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Valued Mentor
    Rich.O.3d
    ASD equivalent of Prosteel unlock constraints to stretch
    434 Views, 3 Replies
    05-22-2012 10:24 PM
    In prosteel, you unlock constraints, then you can use stretch to adjust frames, then you relock constraints.
    Is there a similar method in ASD
    currently when stretching the end of beams, they default to move with amount of the stretch.
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Please use plain text.
    Active Member
    Re: ASD equivalent of Prosteel unlock constraints to stretch
    10-17-2012 12:10 AM in reply to: Rich.O.3d
    Hi I have the same problem, I'm actually disappointed that nobody posted a solution as this is a common operation as designs change constantly and If you have to make rapid changes... Re-assigning all end treatments, grating sizes, hand railing etc. Will be sooooo mundane and time consuming!
    PLEASE SOMEONE HELP
    -=StevieWonder=-
    "Trust me, I'm a draftsman"
    Valued Contributor
    markhubrich
    10-17-2012 10:07 AM in reply to: StevieWonder
    this button right here...
    see attached
    Is this what your looking to do?
    Active Member
    10-17-2012 11:04 PM in reply to: Rich.O.3d
    Hi thanks for the reply!
    Actually no it does not stretch/extend members it also moves them? What I want is for instance a row of secondary beams joining it's main beams e.g. 1000 centers apart and now the the distance changed to 1500 centers apart.
    Now, if I move the main beams to 1500 obviously the secondary beams stay put. Instead of having to go thru the long operation of extending each and every beam and re-attaching it's gussets and cleats etc. I thought I could use the normal stretch tool under  home_modify_stretch and select all member incl. the main beam? This is not stretching the members it only moves them.
    -=StevieWonder=-
