This is a mystery to me. I have two ASD models that I am XReffing into Plant 3D. One I can use OSNAPs just fine, the other will not respond to OSNAPs. Any thoughts, ideas on what to do about this issue? BOth models were created in ASD2014 and I am Xreffing into Plant 3D 2014.
Solved by dennis. Go to Solution.
This is partially explained on the thread http://forums.autodesk.com/t5/AutoCAD-Plant-3D-General/Plant-3d-and-ASD-cannot-cooperate-seamlessly/...
Unfortunatey there is nothing in ASD preferences to set to make it easier in usage.
Thanks Jakub. Not the solution I wanted, but it is the explaination and no need to keep banging me head on this issue.
