• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Active Contributor
    ASD - Reinforcement module - Wish list no. 1 ( Will it be considered ? )
    499 Views, 2 Replies
    02-04-2011 09:11 PM
    I wish I did :
    1- Point reinforcement
                          Automatic distribution of reinforcement
                                                              intersection of bars - this option is not currently available
                                                              tangentially to bar - this option is not currently available
                                                              on bar - this option is not currently available.
    2- Radial reinforcement - bars
                                Circumferential surface reinforcement
        reinforcement shape
        reinforcement parameters are not available.
    3- Radial reinforcement - bars
        reinforcement shape (option to add a straight tangent segment
        at the end of the circular bar). This straigh tangent segment
        can be inside or outside the contour of the circular bar.
    4- Automatic crank (optional) with slope control in
                                                    Bar reinforcement - bar elevation (longitudinal reinforcement)
                                                    Surface reinforcement - bars
                                                    Point reinforcement
    5- Surface reinforcement - bars
                                  Reinforcement - definition and detailing
        parameters of reinforcing bar shape
        The geometry of bar ends incase of sloped bar end
        (option to change the slope amount by adding a new
        parameter such as ” c ” ).
    6- Improvement of Action recorder with all AutoCAD Structural Detailing dialog commands.
    7- Reinforcement bars in the 3D.
    8- Couplers in
                  Point reinforcement
    Please use plain text.
    edugarge
    Re: ASD - Reinforcement module - Wish list no. 1 ( Will it be considered ? )
    02-05-2011 03:41 AM in reply to: abbakeer
    I wish...
    - I could share the same numeration automatically between bars and wire fabrics (e.g. 1-Bar position, 2-Bar position, 3-Wire fabric, 4-Bar position, 5- ..... )
    - I could easily edit all XML databases to adapt them to my country specifications (please, let us do the job if you don't want..Audodesk! because Argentina is not on the host or big countries' list!)
    Thanks!
    Active Member
    02-05-2011 08:16 AM in reply to: abbakeer
    :smileyhappy: I wish that all button from toolbars to work fine (ASD, ACAD, ROBOT). But from 2000 until today I just want :smileysad:. And I have a lot of software from Autodesk.
