AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
ASD Installation error
11 REPLIES 11
Message 1 of 12
gpktm
6433 Views, 11 Replies
I'm trying to install ASD 2013 but i'm getting an Error 1712 all the time and the installation stops.
Here are the few last entries of the log file. You can find attached the whole log file.
Also, the installation window says "Installation Complete" which is definitely is not. The program is not installed.
2012/11/13:13:27:07 Greg GREG-PC === Setup started on GREG-PC by Greg ===
2012/11/13:13:27:07 Greg GREG-PC Launch
2012/11/13:13:27:22 Greg GREG-PC PageOpen LaunchDialog
2012/11/13:13:28:58 Greg GREG-PC PageOpen LicenseDialog
2012/11/13:13:29:01 Greg GREG-PC PageOpen ProductInfoDialog
2012/11/13:13:29:59 Greg GREG-PC PageOpen ProductSelectionDialog2
2012/11/13:13:31:33 Greg GREG-PC PageOpen FullProgressDialog
2012/11/13:13:31:33 Greg GREG-PC Installing DirectX Runtime: C:\Autodesk\ASD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/13:13:32:24 Greg GREG-PC Install DirectX Runtime Succeeded
2012/11/13:13:32:25 Greg GREG-PC Installing AutoCAD® Structural Detailing 2013: TRANSFORMS="C:\Autodesk\ASD_2013_English_Win_64bit\x64\en-us\asd\asd.mst;C:\Users\Greg\AppData\Local\Temp\_AIDAB5.tmp\x64\asd\asd-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\ASD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/13:13:37:09 Greg GREG-PC Install AutoCAD® Structural Detailing 2013 Failed Installation aborted, Result=1603
2012/11/13:13:37:09 Greg GREG-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/11/13:13:37:10 Greg GREG-PC PageOpen InstallCompleteDialog
2012/11/13:13:37:15 Greg GREG-PC === Setup ended ===
2012/11/21:16:55:11 Greg GREG-PC === Setup started on GREG-PC by Greg ===
2012/11/21:16:55:11 Greg GREG-PC Launch
2012/11/21:16:55:23 Greg GREG-PC === Setup ended ===
2012/11/21:16:55:14 Greg GREG-PC === Setup started on GREG-PC by Greg ===
2012/11/21:16:55:14 Greg GREG-PC Launch
2012/11/21:16:55:23 Greg GREG-PC PageOpen LaunchDialog
2012/11/21:16:55:32 Greg GREG-PC PageOpen LicenseDialog
2012/11/21:16:55:36 Greg GREG-PC PageOpen ProductInfoDialog
2012/11/21:16:57:36 Greg GREG-PC PageOpen ProductSelectionDialog2
2012/11/21:16:57:59 Greg GREG-PC PageOpen FullProgressDialog
2012/11/21:16:58:00 Greg GREG-PC Installing DirectX Runtime: C:\Autodesk\ASD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/21:16:59:40 Greg GREG-PC Install DirectX Runtime Succeeded
2012/11/21:16:59:41 Greg GREG-PC Installing AutoCAD® Structural Detailing 2013: TRANSFORMS="C:\Autodesk\ASD_2013_English_Win_64bit\x64\en-us\asd\asd.mst;C:\Users\Greg\AppData\Local\Temp\_AIFFF6.tmp\x64\asd\asd-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\ASD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/21:17:05:39 Greg GREG-PC Install AutoCAD® Structural Detailing 2013 Failed Installation aborted, Result=1603
2012/11/21:17:05:39 Greg GREG-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/11/21:17:05:40 Greg GREG-PC PageOpen InstallCompleteDialog
2012/11/21:17:06:05 Greg GREG-PC === Setup ended ===
2012/11/21:17:07:00 Greg GREG-PC === Setup started on GREG-PC by Greg ===
2012/11/21:17:07:00 Greg GREG-PC Launch
2012/11/21:17:08:20 Greg GREG-PC === Setup ended ===
2012/11/21:17:07:07 Greg GREG-PC === Setup started on GREG-PC by Greg ===
2012/11/21:17:07:07 Greg GREG-PC Launch
2012/11/21:17:07:16 Greg GREG-PC PageOpen LaunchDialog
2012/11/21:17:10:24 Greg GREG-PC PageOpen LicenseDialog
2012/11/21:17:10:27 Greg GREG-PC PageOpen ProductInfoDialog
2012/11/21:17:10:42 Greg GREG-PC PageOpen ProductSelectionDialog2
2012/11/21:17:15:20 Greg GREG-PC PageOpen FullProgressDialog
2012/11/21:17:15:21 Greg GREG-PC Installing DirectX Runtime: C:\Autodesk\ASD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/21:17:17:00 Greg GREG-PC Install DirectX Runtime Succeeded
2012/11/21:17:17:03 Greg GREG-PC Installing AutoCAD® Structural Detailing 2013: TRANSFORMS="C:\Autodesk\ASD_2013_English_Win_64bit\x64\en-us\asd\asd.mst;C:\Users\Greg\AppData\Local\Temp\_AID0DB.tmp\x64\asd\asd-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\ASD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/21:17:21:33 Greg GREG-PC Install AutoCAD® Structural Detailing 2013 Failed Installation aborted, Result=1603
2012/11/21:17:21:33 Greg GREG-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
11 REPLIES 11
Message 2 of 12
Jakub.Brozonowicz
in reply to: gpktm
You cannot install some AutoCAD verticals side-by-side when you have one of the listed products installed, and have this Service Pack applied already.
You will need to uninstall this Service Pack first, before the other listed products can be installed.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Jakub Brożonowicz
Global Product Support
Message 3 of 12
gianghiem
in reply to: gpktm
Firstly, you must uninstall all things related to ASD. After that, you change time system of your computer is 01/01/2012. Finally, you install ASD.
One more solution, you can down autodesk 3D plant suite included ASD and install it.
Good luck.
Message 4 of 12
This is not the problem with activation but installation at all.
Please do not stir the topic.
Jakub Brożonowicz
Message 5 of 12
gpktm
in reply to: Jakub.Brozonowicz
Sorry but I'm somehow confused. What you mean by saying "service pack"? Service Pack of the current program (ASD)?
ASD is not installed at all in my computer, I checked the Autodesk folders. Is it easy to provide step-by-step instructions?
Message 6 of 12
Jakub.Brozonowicz
in reply to: gpktm
First of all, please check if any other AutoCAD...2013 is installed on this machine.
If yes, please check on Control Panel > Programs and Features >View installed updates if any SP was applied.
If yes, please choose Uninstall under RMB on its selection.
You must be sure that none of any AutoCAD's 2013 SP is installed if you want to run installation succesfully just after.
Jakub Brożonowicz
Message 7 of 12
gpktm
I have AutoCAD 2013 Trial and Revit 2013 Trial installed. And in the update list of "Programs and Features" doesn't show any updates from Autodesk. Is it possible to check from the program itslef if any SP are installed?
In the Product Version of AutoCAD says: Product Version: G.114.0.0  I don't know if that helps.
Message 8 of 12
Jakub.Brozonowicz
in reply to: gpktm
It seems wrong.
Please uninstal AutoCAD maybe and try to run ASD installation.
Just hard try.
Jakub Brożonowicz
Message 9 of 12
I deleted SP1 from 2013 and installation is now working.Man LOL
Message 10 of 12
Piotr_Janowski
in reply to: chunkyman
It helped me too. Thx a lot!
Message 11 of 12
Here's a bit of a curveball. I installed a standalone license of the Plant Design Suite Ultimate software package on a machine, and everything will install but Structural Detailing. I spent 2 whole days messing with this thing. It doesn't matter what service pack level is installed, on what partition it's installed, on whether or not I "Run as Administrator," on whether or not I install it together as a suite or separately, on whether I installed from the original flsh stick, downoaded suite, or downloaded Structural Detailing stand alone media--Structural Detailing fails. It just gives that generic Microsoft 1712 error that can be found associated with dozens of failed installations.
The only way it DOES install is if AutoCAD 2013 is not installed at all. For whatever reason AutoCAD, the plain vanilla version of AutoCAD, not mechanical or some other type but just AutoCAD, cannot be installed at the same time that Structural Detailing is installed. My guess is that because AutoCAD is a subset of Structural Detailing, Windows loses its mind and doesn’t know how to handle installing two of the same installations.
The only reason I found that out is because one of my draftsmen wanted to have network licensed Structural Detailing on his machine that is already running a standalone Factory Design Suite Premium 2013, which comes with AutoCAD Mechanical. I warned him that the installation will most likely fail based on my recent experience with the incompatibility between AutoCAD and Structural Detailing. But it made me into a liar and installed without a hitch. I then installed it on machines running Product Design Suite Standard 2012 and AutoCAD 2012 and had no problem at all. BUT when I went to install it on a machine with AutoCAD 2013 I was back to the same 1712 error as before.
As a side note, all of these machines are built with the same Win7Pro syspreped image on Seagate 7200RPM HDDs,16GB RAM or higher, Nvidia Quadro 4000 GPU or higher, Intel DQ77MK motherboard and Intel i5 3570K processor. So I know hardware is not the issue at all.
Message 12 of 12
duchoabn
in reply to: Piotr_Janowski
Dear all
I was removed ASD 2014 from control panel, but when I setup it again. Then display " INSTALLED"
Pl help me to setup it
thank all
”Boost
”Tips
