Every time I try to Auto position parts or Manually position parts the program freezes. This is rediculious. Please tell me someone else is having these issues?
Prin 2006÷2008 era o placere sa lucrezi cu cei de la ROBOBAT. Raspunsuri rapide la probleme, update sau hotfix in max. 2 zile..., dar daca au pensionat echipa ROBOBAT ar trebui sa inchida "chioscul" si sa returneze banii clientilor nemultumiti.
Nu stiu.
A incercat cineva la OPC?
While some AutoDesk personnel come in from time to time, this is user-to-user support. Problems reported here will usually not get logged by AutoDesk. Direct product support isn't delivered through this forum either. Constantly posting won't help get any fix get done faster. Ever had your boss riding your backside to get something done, hovering over your shoulder every few minutes, wondering aloud what they pay you for? Does that make your work go any faster? Thats what you guys are doing here. This isn't a simple "click a toggle box" type of fix, there isn't any skullduggery afoot.
Not only does this not help, the constant unhelpful posts don't make for a welcoming atmosphere for AutoDesk personnel to volunteer additional information or lend a hand. If you wish for more participation by AutoDesk (like a better idea what fixes are being worked on) then a higher level of professionalism will work wonders.
I had to open my file in 2014ASD to do the positioning, can I now open this file in 2015ASD and work with it without issues?
Hi evryone,
Just installed the ACAD 2015 service pack 1 and the positioning bug is dead! I made only few tests, but something is changed!!!
I wish you the best...we are "patience" hero with adsk speed with ASD!!!!
благодаря за точния отговор
спестихте ми много време от ръчно номериране
вече нямам проблеми с номерацията от както прочетох поста ви
Още веднъж благодаря единствено пробвах с 01 за начално и също се получава въпроса е да не е 1
Хубав ден
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
This installation requires you to replace the following file:
