AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
ASD_2014_Layouts_Hotfix is live
1 REPLY 1
Jakub.Brozonowicz
663 Views, 1 Reply
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=21962610&siteID=123112&linkID=12952913
This hotfix will fix the issue with appearing new printing tabs, layouts and product instability related to their usage.
To install ASD_2014_Layouts_Hotfix
You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
This installation requires you to replace the following files:
      • RbctDrawingObj.dbx
      • RbctDrawingMngr.arx
To replace these files
    1. Restart system
    2. Navigate to ASD installation folder; for example C:\Program Files\Autodesk\AutoCAD 2014\ASD
    3. Rename the affected original file:
      • In the product installation folder, right-click the RbctDrawingMngr.arx file and rename it to RbctDrawingMngr.bak
    4. Navigate to AutoCAD 2014 installation folder; for example C:\Program Files\Autodesk\AutoCAD 2014
    5. Rename the affected original file:
      • In the product installation folder, right-click the RbctDrawingObj.dbx file and rename it to RbctDrawingObj.bak
    6. Double click the file:
      • ASD_2014_Layouts_Hotfix_32bit.zip or ASD_2014_Layouts_Hotfix_64bit.zip
    7. Extract RbctDrawingMngr.arx to ASD installation folder; for example C:\Program Files\Autodesk\AutoCAD 2014\ASD
    8. Extract RbctDrawingObj.dbx to AutoCAD 2014 installation folder; for example C:\Program Files\Autodesk\AutoCAD 2014
Jakub Brożonowicz
Global Product Support
1 REPLY 1
What are the beta testers doing? This things should not be present from one version to another. More then that, nothing has been done since de 2012 version.
Regards
Csillag Z.
Regards
Csillag Zoltán
”Boost
”Tips
