• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Member
    ASD 2013 runtime error 440 Automation error
    343 Views, 2 Replies
    12-11-2012 02:07 PM
    Having an issue here where I am trying to set a default template for connections in ASD 2013 and I keep getting this runtime error every time I try to set the template to default and it just closes out of the connections dialog box. Any help would be great.
    Please use plain text.
    Product Support
    Jakub.Brozonowicz
    Re: ASD 2013 runtime error 440 Automation error
    12-12-2012 12:59 AM in reply to: aangelid
    Please try to remove (or rename) ConTmpl.xml file placed in C:\Users\loginname\AppData\Roaming\Autodesk\Structural\Common Data\2013 (W7)
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Member
    12-12-2012 05:35 AM in reply to: Jakub.Brozonowicz
    Wow thank you so much. That worked. I don't need to reinstall anymore.
