The new version of ASD doesn't seem to receive much attention from Autodesk . First there are no noticeable new features , some of the old problems are still present (the incorrect display of welds in 2d drawings for instance) and also there's still no service pack to adress some of the issues , while last year the first sp was out in mid May ...
SP for ASD 2013 is planned to be released with SP for AutoCAD 2013.
Can you give more details concerning the incorrect display of welds?
Best regards,
exam-le of the weld problem , almost anytime the plate isn't parallel to some of the WCS planes something similar happens . Also as you can see even half of the weld isn't displayed at all .
Dear Mr Pawel Pulak,
Could you tell me what happend to this service request case no. 06643972 which was sent to Saikat Bhattacharya on 25.01.2012 19:47
The link below shows the problem
http://www.4shared.com/rar/fSaZA-uw/small_mistake.html
Abbakeer
Dear Mr. Pawel Pulak,
Also, could you please tell me what happened in service request case no. 06643927 regarding Bar end symbol.
Mr. Saikat Bhattacharya from Developer Technical Services sent me two options as shown in the attached file, but since that time (Wednesday, January 11, 2012 11:17 PM) no news.
In addition to the above problem, I sent a proposal to Mr.. Artur Kosakowski from AutodeskSupport Team regarding variable lengths for two different segments within the same bar. I explained to him the possibility to make it using the normal Table commands of the normal AutoCAD which means it will be very easy to ASD developer team to find or create a suitable Macro to execute this feature, but in Monday, January 30, 2012 12:25 PM no positive reply came.
If Autodesk did not intend to update ASD with new features, so what is the benefit of issue a service request case or members' threads and posts showing the problems they have?
Abbakeer
