I am able to create up to 5 tabs per model and file, but if I try to create another layout, I lose a layout tab or two.
You did't lose it... Look in your "printouts" tab in the object inspector. If you aren't using the "object inspector" you will have a tough time in ASD.
Many thanks. I am using the Object Inspector. I can see the Prinouts, but the number of Layout tabs is limited. I can work around this, but it does not seem necessary to limit the number of layout tabs.
I found this bit of information-
type-- setpbuf in the command line. Change the 5 to 30.
now you get 30 views.
Steve
