AutoCAD Structural Detailing General
Active Member
csammons
Message 1 of 4 (572 Views)
ASD 2013 - Limited number of layout tabs?
572 Views, 3 Replies
09-25-2012 11:13 AM
I am able to create up to 5 tabs per model and file, but if I try to create another layout, I lose a layout tab or two.
Valued Contributor
tedmail
Message 2 of 4 (568 Views)
Re: ASD 2013 - Limited number of layout tabs?
09-25-2012 12:06 PM in reply to: csammons
You did't lose it...  Look in your "printouts" tab in the object inspector.  If you aren't using the "object inspector" you will have a tough time in ASD.
Active Member
csammons
Message 3 of 4 (567 Views)
09-25-2012 01:10 PM in reply to: tedmail
Many thanks. I am using the Object Inspector. I can see the Prinouts, but the number of Layout tabs is limited. I can work around this, but it does not seem necessary to limit the number of layout tabs.
Scrambled
Message 4 of 4 (556 Views)
09-25-2012 04:42 PM in reply to: csammons
I found this bit of information-
type-- setpbuf in the command line.  Change the 5 to 30.
now you get 30 views.
Steve
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
