• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Active Member
    ASD 2013 - Limited number of layout tabs?
    370 Views, 3 Replies
    09-25-2012 11:13 AM
    I am able to create up to 5 tabs per model and file, but if I try to create another layout, I lose a layout tab or two.
    Please use plain text.
    Valued Contributor
    tedmail
    Re: ASD 2013 - Limited number of layout tabs?
    09-25-2012 12:06 PM in reply to: csammons
    You did't lose it...  Look in your "printouts" tab in the object inspector.  If you aren't using the "object inspector" you will have a tough time in ASD.
    Active Member
    09-25-2012 01:10 PM in reply to: tedmail
    Many thanks. I am using the Object Inspector. I can see the Prinouts, but the number of Layout tabs is limited. I can work around this, but it does not seem necessary to limit the number of layout tabs.
    Active Member
    09-25-2012 04:42 PM in reply to: csammons
    I found this bit of information-
    type-- setpbuf in the command line.  Change the 5 to 30.
    now you get 30 views.
    Steve
