• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Structural Detailing
    Active Contributor
    ASD 2012 weld description styles
    435 Views, 5 Replies
    10-04-2011 12:47 AM
    is there a way to make weld description style in 2012 version as it was possible in 2011 version? I mean, i want to create my default style with weld hight but no length, and in 2012 default is with weld length, and i have to modify each generated weld descripition manualy, that's really annoying.
    Thanks.
    Please use plain text.
    Product Support
    Jakub.Brozonowicz
    Re: ASD 2012 weld description styles
    10-04-2011 03:43 AM in reply to: maronas
    There is a possible workaround.
    1. Open your default 2011 template.
    2. Insert a single weld with setting the style which you wanted to have as default for automatic operations.
    3. Save as template and migrate it to 2012 by opening a new job using this template.
    4. In 2012 just try to generate automatic welds which should be like 2011 produced.
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Active Contributor
    10-04-2011 06:01 AM in reply to: Jakub.Brozonowicz
    Thanks, this workaround helped!
    Valued Contributor
    markhubrich
    10-06-2011 05:44 AM in reply to: maronas
    Is there a workaround for those of us that did a fresh install of 2012? Also sometimes, all of the time actually, for welds on pipe or other round stuff, the welds get segmented. This creates a million weld symbols on the detail for each little weld segment.
    Is there any way around this? I find myself just turning off the weld marks and manually creating weld symbols.
    Mark
    Product Support
    Jakub.Brozonowicz
    10-06-2011 06:16 AM in reply to: markhubrich
    There are no other way with fresh 2012 rather.
    Only manually inserted welds symbols is reasonable workaround, unfortunately.
    Jakub Brożonowicz
    Support Specialist
    Product Support
    Active Member
    MarcinDyba1906
    11-14-2011 04:14 AM in reply to: maronas
    hi,
    Just type weldmode , and chose 0 for old 2011 and 1 for 2012.
