AutoCAD Structural Detailing General
Active Contributor
maronas
Message 1 of 6 (538 Views)
ASD 2012 weld description styles
538 Views, 5 Replies
10-04-2011 12:47 AM
is there a way to make weld description style in 2012 version as it was possible in 2011 version? I mean, i want to create my default style with weld hight but no length, and in 2012 default is with weld length, and i have to modify each generated weld descripition manualy, that's really annoying.
Thanks.
Product Support
Jakub.Brozonowicz
Message 2 of 6 (531 Views)
Re: ASD 2012 weld description styles
10-04-2011 03:43 AM in reply to: maronas
There is a possible workaround.
  1. Open your default 2011 template.
  2. Insert a single weld with setting the style which you wanted to have as default for automatic operations.
  3. Save as template and migrate it to 2012 by opening a new job using this template.
  4. In 2012 just try to generate automatic welds which should be like 2011 produced.
Jakub Brożonowicz
Active Contributor
maronas
Message 3 of 6 (519 Views)
10-04-2011 06:01 AM in reply to: Jakub.Brozonowicz
Thanks, this workaround helped!
Distinguished Contributor
markhubrich
Message 4 of 6 (506 Views)
10-06-2011 05:44 AM in reply to: maronas
Is there a workaround for those of us that did a fresh install of 2012? Also sometimes, all of the time actually, for welds on pipe or other round stuff, the welds get segmented. This creates a million weld symbols on the detail for each little weld segment.
Is there any way around this? I find myself just turning off the weld marks and manually creating weld symbols.
Mark
Product Support
Jakub.Brozonowicz
Message 5 of 6 (502 Views)
10-06-2011 06:16 AM in reply to: markhubrich
There are no other way with fresh 2012 rather.
Only manually inserted welds symbols is reasonable workaround, unfortunately.
Jakub Brożonowicz
Active Member
MarcinDyba1906
Message 6 of 6 (403 Views)
11-14-2011 04:14 AM in reply to: maronas
hi,
Just type weldmode , and chose 0 for old 2011 and 1 for 2012.
You are not logged in.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
