• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Structural Detailing
    Valued Contributor
    ASD 2012 reinforcement
    1141 Views, 2 Replies
    05-20-2011 01:36 PM
    Where we can find the new tool for 3d reinforcement ???????????????
    Please use plain text.
    Product Support
    jad.dellel
    Re: ASD 2012 reinforcement
    05-26-2011 12:23 AM in reply to: ZHUKOV_ING
    When you design your Rc beam, use the Objet Inspector, select your beam in the tab Model,  right click and "Create 3D view" .
    Cheers,
    Jad DELLEL
    Structural Engineering Product Support Autodesk, Inc.
    Valued Contributor
    10-02-2012 06:45 AM in reply to: jad.dellel
    Hi! I am using ASD 2013 and modeling a foundation slab (reinforceing it) - when I do the option you've mentioned in a post above I only can see the formwork of the slab without reinforcement - how to make it visible?
    I also created some basic elements with the help of a tab ASD - Structure Elements -> (Panel) Structure Elements Reinforcement: Beam, Column, Spread footing - and every option from this list I could visiolize in 3D and COULD see the reinforcement.
