AutoCAD Structural Detailing General DIscussion
Active Member
Spageddie
Message 1 of 4 (500 Views)
ADS and Navisworks
500 Views, 3 Replies
06-11-2008 11:16 PM
I am currently testing ADS's abilities and am having trouble viewing it's models in Navisworks.
Is there a specific set of object enablers for this ?
Any assistance would be appreciated.
Eddie
Distinguished Contributor
freemail
Message 2 of 4 (500 Views)
Re: ADS and Navisworks
06-12-2008 12:07 AM in reply to: Spageddie
Please see:
http://www.robobat.com/n/en/320/1
Valued Contributor
huyxp
Message 3 of 4 (242 Views)
04-17-2013 05:24 PM in reply to: freemail
link die
please check again
markhubrich
Message 4 of 4 (158 Views)
05-12-2013 09:21 PM in reply to: Spageddie
If you installed the Navisworks Exporters during the install, follow instruction in the Navis exporter docs and try out the NWCOUT command. By habit I export to a seperate folder than where my dwg is kept. This was due to some issues in the past when the BIM coordinator is working with and updating their NWF files from my live files. It may not be an issue any more though.
You could also look at your Navisworks export settings with NWOPT command. If your using the Navisworks Freedom viewer, you may need to use the NWDOUT command in ASD due to the Freedom limitations. I believe it only opens NWD files.
Announcements
Need installation help?
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
