• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Raster Design
    Active Member
    would like Rasterdesign 2008 to launch when Autocad drawing opens
    532 Views, 8 Replies
    05-23-2010 10:16 PM
    I have Rasterdesign 2008 and Autocad 2008 on my computer,
    I would like to have Rasterdesign Launch whenever an autocad
    drawing file is opened.
    At present if i double click on a drawing file- the drawing will open
    in Autocad without activating Rasterdesign - how can i get Rasterdesign
    to open automatically, with out having to manually open it by
    double clicking on the desktop icon.
    Thanks for any help.
    Please use plain text.
    *Matthew Osborn
    Re: would like Rasterdesign 2008 to launch when Autocad drawing opens
    05-24-2010 07:29 AM in reply to: TWJ13
    Raster Design should automatically load once you issue a raster command. There is no need to launch from the desktop icon.
    Matt
    wrote in message news:6396018@discussion.autodesk.com...
    Active Member
    05-24-2010 07:37 PM in reply to: TWJ13
    Matt
    Thank for the reply Matt -
    When i do issue a raster command - i get an error message - and no raster commands are possible -
    So i have to close out Autocad and open Rasterdesign using the desktop icon in order to get it to work.
    I can't rememeber the exact error message - as i am away from my job computer. (but i believe it is looking for an AeciUi51.arx file or something like that, I will have to check the exact error message)
    But the main issue is that when ever i open a raster file it will open autocad but it never launches the rasterdesign commands.
    The commands appear but when selected - the error message comes up. (is this normal or is there some other issue).
    Troy
    Active Member
    05-25-2010 04:15 AM in reply to: TWJ13
    In my previous response I mentioned the message that I got when opening a raster file
    This was incorrect. (I've had a chance to check the exact messege)
    It reads:
    "AeciRemUi51.arx cannot find a dll or other file that it needs"
    This occurs after the raster file has opened - when i try to select
    a raster command.
    Any idea how to correct this?
    Troy
    *Rowland
    05-25-2010 04:59 AM in reply to: TWJ13
    You are more than likely missing a path statement in Acad.
    Search your system for that missing file, then add that path to AutoCAD
    thru Tools > Options > Files tab > Support File Search Path
    After that, RD should start when you access one of the Image commands in
    Acad.
    Active Member
    05-25-2010 06:57 AM in reply to: TWJ13
    Thanks Rowland.
    I will see how this goes.
    Troy
    Active Member
    05-25-2010 07:40 AM in reply to: TWJ13
    Rowland
    Thanks so so so much.
    That solved the problem - You've saved me a great deal of time - and headaches.
    Much appreciated.
    Troy
    Thanks also to Matt - for your assistance with my initial Question.
    *Rowland
    05-25-2010 08:01 AM in reply to: TWJ13
    glad I could help Troy.
    *Matthew Osborn
    05-25-2010 10:31 AM in reply to: TWJ13
    Yes, the support file search path problem is common. It seems that some service packs end up removing the Raster paths.
    Matt
    wrote in message news:6396844@discussion.autodesk.com...
    Rowland
    Much appreciated.
    Troy
