• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Raster Design
    *Trudel, JP
    Shift key with Raster Design
    181 Views, 3 Replies
    08-25-2003 02:34 AM
    deos some of you had experiment a promblem with shift key to select multiple
    grips or unselect object ?
    JP
    Please use plain text.
    *Fuls, Karl
    Re: Shift key with Raster Design
    08-25-2003 04:13 PM in reply to: *Trudel, JP
    I believe the shift-pick combo will select the image if you pick inside it's
    boundary. This does allow you to select an image without zooming out so you can
    see it's boundary but it does conflict with other uses of this combination.
    _____________
    Karl M. Fuls PLS
    AEC Training and Consulting
    Assistant Moderator - Autodesk Discussion Forums
    Please state the version of your software and the operating system you are using
    to facilitate better replies.
    JP Trudel wrote:
    > Hello,
    > JP
    *Jessup, Allen
    Re:
    08-25-2003 10:15 PM in reply to: *Trudel, JP
    This can be controlled through the options in RD. Go to Mouse Settings on
    the User Preferences tab.
    Allen
    "Karl Fuls" wrote in message
    news:3F4B0894.F216C34D@adelphia.net...
    it's
    you can
    combination.
    > _____________
    > Karl M. Fuls PLS
    using
    > JP Trudel wrote:
    > > Hello,
    multiple
    > > JP
    *Trudel, JP
    Re:
    08-26-2003 08:37 AM in reply to: *Trudel, JP
    Thank's
    JP
    "Karl Fuls" a écrit dans le message de news:
    it's
    you can
    combination.
    > _____________
    > Karl M. Fuls PLS
    using
    > JP Trudel wrote:
    > > Hello,
    multiple
    > > JP
