• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Raster Design
    New Member
    Raster Image Frame Do Not Plot
    1889 Views, 3 Replies
    03-10-2010 11:28 AM
    How do I make the raster image frame not plot? If I turn off or freeze the layer the intire image goes away.
    Please use plain text.
    *Matthew Osborn
    Re: Raster Image Frame Do Not Plot
    03-10-2010 12:16 PM in reply to: PQuick
    Can't you just turn off the frames with IFRAME?
    Matt
    wrote in message news:6352420@discussion.autodesk.com...
    New Member
    03-10-2010 12:49 PM in reply to: PQuick
    I found through a google search- the command is "imageframe." Settings 1 for on and 0 for off.
    Valued Contributor
    03-10-2010 03:03 PM in reply to: PQuick
    If you are 2006 or later you can also use imageframe = 2. Image frame shows and is selectable but does not plot.
    Patrick
