• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Raster Design
    New Member
    Raster Design 2013 Crashes
    979 Views, 0 Replies
    07-20-2012 09:08 AM
    I just loaded Civil 3D and Raster 2013. All seemed fine until I tried to use Raster Insert to insert a georeferenced quad, also tried other images. If I try to transform an image to my present coordinate system based on True (pixel by pixel) or 4 point rubbersheet AutoCAD crashes. No error message is displayed just a freeze. Once you check in Task Manager acad.exe is not responding but the memory usage continually increases until you hit the max and the computer crashes. I have tried to fix both programs and I have also reinstalled both programs. Just for extra information this has been tried on two separate computers with the same outcome. I am running as a stand-alone non-networked AutoCAD. I can insert an image with no transformation or by using the 3 point affine transformation. The 3 point affine may work for now but it does not allow the image to be manipulated. Anyone else having this problem or have any possible solutions.
    Jim K
    Please use plain text.
