• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Raster Design
    Valued Mentor
    Re: Raster Design 2012
    05-24-2011 05:15 AM in reply to: snakerancher
    RD 2012 arrived via download this a.m.  loaded it up.  so far won't iinsert a 25066 kb MrSid without crashing Map3D 2012 and after using mapiinsert command to load the sid I tried to save the image to jpg. it crashed at 54% saved.  SOSDD!
    dave
    Please use plain text.
    Distinguished Contributor
    05-24-2011 05:55 AM in reply to: parkr4st
    Dave, I loaded a 2MB JP2 with no problem using raster. I usually use the data connect to attach image files. Not sure what the issue is, what are your machine specs?
    Member
    mohl
    05-25-2011 12:26 PM in reply to: snakerancher
    Has anyone tried to build a 64 bit deployment package for Raster Design 2012?  I get to the point where I enter the configuration name, Admin image path, target platform and installation settings.  As soon as I have them set, I click on Next and get the error "Error 1723.  There is a problem with this Windows Installer package.  A DLL required for this install to complete could not be run.  Contact your support personnel or package vendor."  After I click OK to the message, I get "Fatal error during installation.  #2178: failed to run AdskExecuteSequence.".  Clicking OK to that error gives me "Failed to initialize AutoCAD Raster Design 2012".  After these 3 errors, it takes me back to the configuration screen, but is locked up and I need to use Task manager to kill the process.
    Help please?
    Member
    mohl
    05-25-2011 12:28 PM in reply to: mohl
    In addition to the above post, I tried to re-download the raster package and ended up with the same result.  The 32 bit version builds without issue.
    I've been building these packages on a Windows 7 32 bit PC and my 64 bit versions of AutoCAD, Map3D and LT all built without issue.
    Valued Mentor
    05-25-2011 01:08 PM in reply to: snakerancher
    snakerancher
    Processor Intel(R) Pentium(R) D  CPU 2.66GHz, 2654 Mhz, 2 Core(s), 2 Logical Processor(s)  32 bit
    ATI Firepro V5800(FireGL) video w/3 monitors
    redundant 1t HDs
    4 GB ram/3 available to Map3d
     WIN 7 PRo  SP 1
    Map3d2012
    RD2012
    dave
    *Expert Elite*
    johnm
    06-02-2011 12:25 PM in reply to: mohl
    I get the same behaivor. I can build a 32 bit deployment but not a 64 bit. I get the same FE #2178.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    *Expert Elite*
    johnm
    06-08-2011 09:17 AM in reply to: mohl
    You cannot create a 64 bit deployment from a 32 bit machine. Run setup from a 64 bit client (Run as Administrator) and save the deployment to the network location of your choice.
    This tip came from Subscription Support and I am up and running.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    New Member
    Raster Design 2012
    04-22-2013 06:19 AM in reply to: snakerancher
    Trabalho com imagens de projeto de ruas na prefeitura municipal de curitiba. Separo em camadas preto e vermelha. A camada preta nunca mudo por isso fica com o cadeado fechado. A camada vermelha é a que preciso vetorizar, apagar. Mas quando uso a ferramenta "remove", fica uma mancha preta. Sempre deu certo, mas desde que foi feita atualização para o Rasterdesign 2012, não consigo apagar a imagem sem aparecer esta mancha. Segue um anexo com o problema. Desde já agradeço a ajuda.
