AutoCAD Raster Design
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Raster Design 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
RD 2012 arrived via download this a.m. loaded it up. so far won't iinsert a 25066 kb MrSid without crashing Map3D 2012 and after using mapiinsert command to load the sid I tried to save the image to jpg. it crashed at 54% saved. SOSDD!
dave
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Has anyone tried to build a 64 bit deployment package for Raster Design 2012? I get to the point where I enter the configuration name, Admin image path, target platform and installation settings. As soon as I have them set, I click on Next and get the error "Error 1723. There is a problem with this Windows Installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor." After I click OK to the message, I get "Fatal error during installation. #2178: failed to run AdskExecuteSequence.". Clicking OK to that error gives me "Failed to initialize AutoCAD Raster Design 2012". After these 3 errors, it takes me back to the configuration screen, but is locked up and I need to use Task manager to kill the process.
Help please?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In addition to the above post, I tried to re-download the raster package and ended up with the same result. The 32 bit version builds without issue.
I've been building these packages on a Windows 7 32 bit PC and my 64 bit versions of AutoCAD, Map3D and LT all built without issue.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
snakerancher
Processor Intel(R) Pentium(R) D CPU 2.66GHz, 2654 Mhz, 2 Core(s), 2 Logical Processor(s) 32 bit
ATI Firepro V5800(FireGL) video w/3 monitors
redundant 1t HDs
4 GB ram/3 available to Map3d
WIN 7 PRo SP 1
Map3d2012
RD2012
dave
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I get the same behaivor. I can build a 32 bit deployment but not a 64 bit. I get the same FE #2178.
C3D 2012, RD 2012
Win 7 64, Core i7,
6 GB RAM, Quadro FX 1700
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You cannot create a 64 bit deployment from a 32 bit machine. Run setup from a 64 bit client (Run as Administrator) and save the deployment to the network location of your choice.
This tip came from Subscription Support and I am up and running.
C3D 2012, RD 2012
Win 7 64, Core i7,
Raster Design 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Trabalho com imagens de projeto de ruas na prefeitura municipal de curitiba. Separo em camadas preto e vermelha. A camada preta nunca mudo por isso fica com o cadeado fechado. A camada vermelha é a que preciso vetorizar, apagar. Mas quando uso a ferramenta "remove", fica uma mancha preta. Sempre deu certo, mas desde que foi feita atualização para o Rasterdesign 2012, não consigo apagar a imagem sem aparecer esta mancha. Segue um anexo com o problema. Desde já agradeço a ajuda.
