• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Raster Design
    Valued Contributor
    Raster Design 2010?
    936 Views, 1 Replies
    12-20-2011 08:11 AM
    I am using Autocad 2010 and want to try out Raster Design. Autodesk only allows me to download the Raster Deseign 2012 version, which will not install on my computer because I am not running Autocad 2012.
    Is there a way to get a trial copy of RD 2010?
    Or, is there a way to get the RD 2012 to install side by side with my Autocad 2010?
    Pretty sad that you cannot even try out software because you have not updated to another version and a different software. Go Autodesk!! They will do anything to force you into upgrading, even if it's not in your best interest.
    Thanks for any help.
    CD
    Please use plain text.
    Active Contributor
    Re: Raster Design 2010?
    06-11-2012 12:38 PM in reply to: cadiehl
    The only way to try Raster Design 2012 out that way is to download a trial version
    of AutoCAD 2012 the same as the Raster Design trial version. Then when you
    purchase you can get a downgrade to the AutoCAD 2010.
