• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Raster Design
    Distinguished Contributor
    Raster 2011 file search path and menus
    364 Views, 0 Replies
    01-23-2013 04:33 PM
    I’m having a weird issue with the File Support Search Path and Raster 2011 and different profiles.  When I launch Raster on a user machine it will not load menus.
     That is because the search path in this particular profile is set to:
    C:\users\<user name>\Appdata\Roaming…etc.
    The only way to fix it is to switch to a profile that has the path set to:
    C:\users\Administrator\Appdata\Roaming…etc.
    That is where the AecCo.cuix menu is installed.
    I could have sworn it was the user’s roamable root that is configured for the menu.  Is the Administrator's path correct?  If not, how do I set it correctly?
    Please use plain text.
