• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Raster Design
    Active Contributor
    Accepted Solution
    Raster 2009 with Civil 2009 on 64 bit Windows 7
    3092 Views, 6 Replies
    11-06-2009 11:11 AM
    I've installed Civil 3D 2009 64-bit on a Windows 7 computer. The install places the installation in c:\programs files (x86)
    Civil 3D 2009 works fine.
    Then, I run the deployment for Raster Design 2009 64-bit (RD) on the machine. RD gets installed under c:\program files
    I try to initialize RD by launching the icon it created, and immediately it says something like 'path to acad.exe not found' -- so I browse for it (by default, it's looking for acad.exe in c:\program files, when it's acually under c:\program files (x86). I browse to c:\program files (x86)\autocad civil 3d 2009 and select acad.exe found there. The program launches fine, but none of the RD commands work. I try to insert an image, and get "unknown command".
    1. Is there something I can do to NOT get the missing acad.exe when I launch the RD icon
    2. Is #1 the reason why none of the commands in RD work after launching.
    I feel like I'm missing a major hotfix here -- one that doesn't exist yet for Windows 7. My RD is up to date with all of the other updates and 64-bit hot fixes. Thanks,
    -Anton
    Please use plain text.
    *wfb
    Re: Raster 2009 with Civil 2009 on 64 bit Windows 7
    11-07-2009 05:21 AM in reply to: aflewelling
    There is a small problem with installing Raster Design on a 64 bit operating
    system. Since you did the deployment method I cannot answer directly, but
    the installation will not even work when installed with the DVD so here is
    what I have to do:
    http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=11326243&linkID=9240697
    Good Luck,
    Bill
    wrote in message
    news:6285019@discussion.autodesk.com...
    "unknown command".
    launch the RD icon
    hot fixes. Thanks,
    -Anton
    Active Contributor
    Re: Raster 2010 with Civil 3D 2010 on 64 bit Windows 7
    02-03-2010 07:09 AM in reply to: aflewelling
    Hey, I am having a similar problem, but it is with 2010 products on a Windows 7 64-bit machine. Raster Design works with AutoCAD 2010, but does not work with Civil3D 2010. The link for the fix above does not work. Can someone help?
    Active Contributor
    02-05-2010 06:27 AM in reply to: aflewelling
    Link is broken. Here is the contents and the solution (apparently, you can only have Raster Design work for EITHER 64 bit installs (autocad, map, etc.) OR 32-bit installs (civil 3d). You have to pick one.
    -Anton
    Published date: 2009-Dec-15
    Applies to:
    AutoCAD® Civil 3D® 2010
    AutoCAD® Civil 3D® 2009
    AutoCAD® Land Desktop 2009
    AutoCAD® Map 3D 2009
    AutoCAD Raster Design 2009
    You installed a 32-bit version of AutoCAD® 2009 or 2010 or other AutoCAD vertical product, such as AutoCAD® Map 3D 2009, AutoCAD® Civil 3D® 2009, or AutoCAD® Civil 3D® 2010, on your 64-bit operating system. However, when you tried to install AutoCAD Raster Design 2009 or 2010 and link it with these products, you received the following error message:
    No supported desktops for AutoCAD Raster Design 2009 were found...
    Please Exit and Install a supported desktop before proceeding.
    This error message indicates that the installer was not able to find a 64-bit application.
    To correct this issue, you need to redirect the installer to look for 32-bit applications on the 64-bit operating system. Follow these steps:
    Copy the entire contents of the installation disk to a folder on the hard drive.
    In the root of this folder, locate the Setup.ini file and open it with Microsoft® Notepad.
    Under [SETUP], modify the line below as follows:
    Old line: x64_IMAGE_PATH=x64
    New line: x64_IMAGE_PATH=x86
    Save and close the Setup.ini file.
    In the root of this folder, run the Setup.exe file.
    Note: The following is a known feature limitation of AutoCAD® Map 3D 2009 on 64-bit operating systems:
    The Map Image Insert command (MAPIINSERT) does not work.
    Active Contributor
    02-05-2010 06:58 AM in reply to: aflewelling
    Thank you for posting that. I hope it works with my setup. I have already installed RD and it works with AutoCAD. I guess when I install it for C3D it will stop working for AutoCAD and MAP?
    Active Contributor
    02-05-2010 07:42 AM in reply to: aflewelling
    Yes, I'm pretty sure you can only have Raster Design work in 64 bit mode, or 32 bit mode, and not both. I'd assume you'd have to uninstall Raster Design, and reinstall it using the fix. It seems you have to pick which format is most important to you! Sucks if you have limited licenses of Civil 3D, and use Autocad&Map3d&Civil 3D on the same machine to gain access to a larger license pool (as we do at our office).
    Distinguished Contributor
    03-15-2010 11:04 AM in reply to: aflewelling
    You can't run Raster Design on Civil 3D & AutoCAD 64 bit (assuming your ACAD is true 64). It does suck. we have 3rd party apps that support AutoCAD updates in a more timely fasion. Raster is not supported on Windows 7 yet it's recomended for Civil 3D.
    You might try installing it twice & see what happens. I had Architecture which is true 64 and C3D on the same machine and Raster worked on Arch but not C3D. I did the fix above and it works on C3D & not Arch. I don't need it to run in Arch so I did go any further with it.
    Here are a few other things:
    You can edit the target string on the icon to point to the correct location. I added an icon for Raster into my C3D deployment with the correct argument.
    Make sure all you have all these support paths, I add them into the arg file manually because RD historically has done a poor job of doing it automatically:
    C:\Program Files\AutoCAD Raster Design 2010
    C:\Program Files\AutoCAD Raster Design 2010\Help
    C:\Program Files\Raster Design 2010 OE
    C:\Program Files\Common Files\Autodesk Shared\AxUi
    This hot fix resolved some issues I was having saving files in RD:
    http://usa.autodesk.com/getdoc/id=DL13435443
