• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Raster Design
    *Arvanitopoulos, Panos
    RD 2004 Error
    186 Views, 3 Replies
    10-08-2003 04:13 AM
    I have installed RD 2004 on Land Desktop 2004
    in a PC with WinXP Pro SP1.
    (All hotfixes for O.S., IE 6 SP1 and Land Desktop 2004 are also installed)
    When I try to detach an image with MANAGE command ( RD menu ), the program
    send a FATAL ERROR : "Unhandled Access Violation Reading 0x0010 Exception at
    644fbe53h"
    The others selections in MANAGE command works well ( Unload, Reload )
    So I use Image Manager command ( AutoCAD Insert Menu ) to workaround the
    problem.
    Can anyone help on this problem ?
    with friendly greedings from Greece
    Please use plain text.
    *support], Jon Golubiewski [Autodesk
    Re: RD 2004 Error
    10-16-2003 01:53 AM in reply to: *Arvanitopoulos, Panos
    Hi Panos,
    This is a known issue and you have identified one of the work-arounds.
    Please see the following solution for more information:
    TS80136 FATAL ERROR: Unhandled Access Violation Reading 0x0010 Exception at
    644fedfbh
    http://usa.autodesk.com/getdoc/id=TS80136
    Jonathan Golubiewski
    Autodesk Professional Services
    Land.Civil.Survey
    "Panos Arvanitopoulos" wrote in message
    news:46AB13AB5E936E5A598E042D211FF2B1@in.WebX.maYIadrTaRb...
    at
    > 644fbe53h"
    > problem.
    Re:
    10-18-2003 10:39 AM in reply to: *Arvanitopoulos, Panos
    Thanks a lot for your response.
    An other general question about bugs in Raster Design is that we read a lot
    of answers from Autodesk moderators that these bugs are by design but never
    Autodesk released any Service Pack for Cad Overlay or Raster Design.
    Is there any posibility to change this policy in the immediate future ?
    Thanks again
    Surveyor Engineer
    "Jon Golubiewski [Autodesk support]"
    wrote in message
    news:F9139F3279074B25CD89DA8B4CB94967@in.WebX.maYIadrTaRb...
    > Hi Panos,
    at
    > 644fedfbh
    > Land.Civil.Survey
    installed)
    program
    Exception
    > at
    > > 644fbe53h"
    > > problem.
    Re:
    10-19-2003 11:53 PM in reply to: *Arvanitopoulos, Panos
    Panos,
    I'd like to assure you that the need for a service pack is very carefully
    considered by many departments against many factors. There is a great
    amount of effort involved in releasing a service pack: determination of
    issues to be addressed, making those changes, testing those changes, testing
    to make sure that those changes have not had a negative affect on anything
    else in the product or other products, etc... Issues may be fixed either in
    a service pack or in the next release. Each "opportunity" for a service
    pack has and will be carefully considered by the appropriate teams.
    Although there have been no full service packs for Raster Design, there have
    been several individual issues addressed by individual updates under the
    Raster Design Data & Downloads area
    (http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&l
    inkID=2476535). There are currently no updates or service packs available
    for Raster Design 2004.
    Land.Civil.Survey
    news:E59A3AC653FBE488D9CC424CE5FBFE65@in.WebX.maYIadrTaRb...
    lot
    never
    > Thanks again
    > Surveyor Engineer
    > wrote in message
    > > Hi Panos,
    > at
    > > 644fedfbh
    > > Land.Civil.Survey
    > installed)
    > program
    > Exception
    > > at
    > > > 644fbe53h"
    the
    > > > problem.
