• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Raster Design
    New Member
    Partial CUI
    562 Views, 1 Replies
    12-18-2012 04:46 PM
    I am running into a problem.
    I am loading the AUTOCADRASTERDESIGN partial CUI into my Enterprise CUI.
    However when I switch out of my CAD_Support profile into my base profile that all my users will have ACAD displays AeciRibbonUiApi... Now if I click into View or hit escape in get my Command:
    When I remove the AUTOCADRASTERDESIGN partial CUI from my Enterprise CUI and load it into my base profile partials it doen't act like this.
    Any idea's to why it is staying on Loading AeciRibbonUiApi... instead of returning to a Command:
    It's more of an annoyance right now, as it doesn't really cause an issue because I am just now working on setting up our 2012 upgrade but I know I will have users asking me why its hanging when it's not it just leaves that line.
    Sean
    Please use plain text.
    New Member
    Re: Partial CUI
    12-19-2012 08:51 AM in reply to: SeanMallonee
    After doing some more testing.
    First - After AutoCAD load I select the Raster Tools Ribbon and open Options a few more Raster codes load up and I am back to a Command:
    Second - If I leave Raster Design Ribbon up when closing AutoCAD then re-open it I don't get the same (visual) glitch in the command window.
    So right now I have confirmed that this is only a visual glitch and doesn't effect the operation of the software however annoying it may be.  It looks as if when the Raster Design menu is loaded as a partial into the enterprise cui the final COMMANDLINE command does not run to put the command window at the Command: prompt.
    Anyone else seeing this or that can reproduce it?
    Sean
