• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Raster Design
    Active Contributor
    Image tab does not show up on ribbon
    3272 Views, 3 Replies
    07-28-2010 02:53 PM
    I installed raster 2011 and start Architecture using the RD for Architecture shortcut and there is no IMAGE tab in the ribbon. How do I get to the RD tools?
    Please use plain text.
    Product Support
    Re: Image tab does not show up on ribbon
    07-29-2010 09:50 AM in reply to: davidm
    First off you might be like me and have to translate many years of using “Image” for the Menu or Ribbon tab name to “Raster Tools.“ It is now "Raster" for the Menubar and "Raster Tools" for the Ribbon.
    Next double check that you have a Workspace loaded.
    Then check that the Partial CUI for AutoCAD Raster Design 2011 is loaded:
       Vista and Windows 7: C:\Users\%username%\AppData\Roaming\Autodesk\ARD2011\R18.1\enu\Support\AecCo.cuix
       XP: C:\Documents and Settings\%username%\Application Data\Autodesk\ARD2010\R18.0\enu\Support\AecCo.cuix
    AutoCAD Raster Design 2011 also requires these additional Support File Search Paths:
       C:\program files\autodesk\raster design 2011 oe
       A user profile folder:
               XP: C:\Documents and Settings\%username%\Application Data\Autodesk\ARD2011\R18.1\enu\Support
       C:\program files\autodesk\autocad raster design 2011
       C:\program files\autodesk\autocad raster design 2011\help
    Let us know how things work out.
    Douglas Lauritsen
    Support Specialist
    Product Support
    Active Contributor
    07-29-2010 11:06 AM in reply to: DouglasLauritsen
    Yea, Raster tools, that's what I meant to say :smileywink:
    Checked under workspaces, something I never use (for lack of understanding it) but found two workspaces. Architecture (checked) and Architecture - migrated from 2010. I checked the latter and sure enough there they were. Thanks much, now I need to learn about workspaces.
    Distinguished Contributor
    07-30-2010 09:01 AM in reply to: davidm
    I noticed that happening to all my 2011 Raster installs.  Try and repair the install, Raster Tab should show up.
