• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Raster Design
    Member
    Image insert of non uniform X Y SCALE Raster
    297 Views, 4 Replies
    02-02-2006 04:54 AM
    I am Working with AutoCAD MAP 2002
    I Insert a Raster file ((JPG) who was rubber sheet to it's coordinate By Raster Design method and was export by raster design tools with burn rotation and world file) By Map>Image >Insert
    The raster's was out of place by 800 meters
    The JGW has a non uniform X Y Scale.
    I need that the raster's will be insert in it place in AutoCAD Map 2002. as the same place it is in the Raster Design.
    Do the methods of INSERT in ACMAP 2002 is different from ACMAP 2002 Raster Design and what are the differences in the Calculation?
    Dose the Size of the area in raster influence on the INSERT Method?
    Dana
    Please use plain text.
    *Phil Daley
    Re: Image insert of non uniform X Y SCALE Raster
    02-02-2006 05:46 AM in reply to: danay
    Map doesn't know how to Rubber Sheet. Inserting a differential X-Y
    image in Map will be different than inserting that same image with
    Raster Design.
    Phil Daley
    Member
    02-02-2006 07:11 AM in reply to: danay
    Map knows how to rubber sheet.
    but the raster I work with has been rubbersheet and export from Raster design.
    *Phil Daley
    02-02-2006 10:47 AM in reply to: danay
    Map knows how to move the corners of the image, Raster Design knows
    how to move the pixels, modifying the image. That is different.
    Phil Daley
    Valued Contributor
    05-08-2008 04:01 AM in reply to: danay
    check your units in the drawing. with large images that cover a lot of area your units need to be set to the highest possible angular precision to. i've brought images in with the units at their default values and have notices a large shift in the position of the image.
