• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Raster Design
    *Mike
    Deselect
    2210 Views, 8 Replies
    06-05-2007 06:53 AM
    For some reason whenever i load ARD into AutoCAD i can no longer shift+left
    click to deselect items in ACAD. Ive had this problem since ARD 2006. Anyone
    else have this problem?
    Mike
    Please use plain text.
    *Mike
    Re: Deselect
    06-05-2007 07:04 AM in reply to: *Mike
    I have isolated the problem to the file AECiUi51.arx, whenever this file is
    loaded i can no longer use my shift+click to deselect items.....
    "Mike" wrote in message
    news:5616506@discussion.autodesk.com...
    Mike
    *Matt Osborn
    Re: Deselect
    06-05-2007 07:10 AM in reply to: *Mike
    IOPTIONS.
    User Preferences tab, under Mouse Settings; uncheck "Shift-Left click image
    select".
    Matt
    Mike
    *Mike
    Re: Deselect
    06-05-2007 09:05 AM in reply to: *Mike
    Of course it had to be something easy and stupid on my part. Who in their
    right minds would bother checking all the options..... :smileysad:
    Mike
    "Matt Osborn" wrote in message
    news:5616538@discussion.autodesk.com...
    IOPTIONS.
    select".
    Matt
    Mike
    Valued Contributor
    Re: Deselect
    06-13-2007 01:24 PM in reply to: *Mike
    Don't feel bad. I found out because I talked to an Autodesk employee & was grumbling about it then he told me how to fix it. I had been using RD for 3 or 4 years by that time.
    Active Member
    Re: Deselect
    01-23-2008 11:17 AM in reply to: *Mike
    I am having this same issue.... I am running A.cad LT2008 on a Parallels Mac program...
    Can anyone help!
    Active Member
    Re: Deselect
    I tried the above solution and I don't have a mouse options button?
    *Matt Osborn
    Re: Deselect
    01-23-2008 11:58 AM in reply to: *Mike
    You're not having the same issue, as Raster Design does not even run on LT.
    wrote in message news:5828410@discussion.autodesk.com...
    Can anyone help!
    Re: Deselect
    01-25-2011 08:46 AM in reply to: *Matt Osborn
    It took a long time before I figured out "I(eye)Options".
    I didn't know all that was there.
    I've been having the same problem for a long time now.
    Do enough research, and you can sometimes, find the answer.
