• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Raster Design
    New Member
    ges87401
    2011 AutoCAD Raster Image Embed problem?
    1614 Views, 2 Replies
    01-11-2012 12:15 PM
    We are using images from a Satellite Imagery company. The TIFF image is around 6 megs in size and after trying to use the image embed command from the raster image the command line reads "1 image(s) filtered out, 0 image(s) embedded". We've looked at most of the commands and can't find a solution. Any help would be appreciated.
    Please use plain text.
    Distinguished Contributor
    Re: 2011 AutoCAD Raster Image Embed problem?
    07-23-2012 10:51 AM in reply to: ges87401
    Try inserting the image into Microsoft Word first and then copy and paste from Word to AutoCAD.
    Active Contributor
    01-29-2013 05:58 AM in reply to: Rainman1
    late post,,,,try making a new layer 'tif' and the color white, put your .tif file on this layer...when u do the iembed command it should not say there was any filtered out,,,,just one embedded...if it does delete the .tif and check ur xref manager an detach...start over inserting .tif file and put on tif layer,,iembed should work then.
