AutoCAD Raster Design Forum
would like Rasterdesign 2008 to launch when Autocad drawing opens
8 REPLIES 8
Message 1 of 9
TWJ13
828 Views, 8 Replies
I have Rasterdesign 2008 and Autocad 2008 on my computer,
I would like to have Rasterdesign Launch whenever an autocad
drawing file is opened.
At present if i double click on a drawing file- the drawing will open
in Autocad without activating Rasterdesign - how can i get Rasterdesign
to open automatically, with out having to manually open it by
double clicking on the desktop icon.
Thanks for any help.
8 REPLIES 8
Message 2 of 9
in reply to: TWJ13
Raster Design should automatically load once you issue a raster command. There is no need to launch from the desktop icon.
Matt
wrote in message news:6396018@discussion.autodesk.com...
Message 3 of 9
TWJ13
in reply to: TWJ13
Matt
Thank for the reply Matt -
When i do issue a raster command - i get an error message - and no raster commands are possible -
So i have to close out Autocad and open Rasterdesign using the desktop icon in order to get it to work.
I can't rememeber the exact error message - as i am away from my job computer. (but i believe it is looking for an AeciUi51.arx file or something like that, I will have to check the exact error message)
But the main issue is that when ever i open a raster file it will open autocad but it never launches the rasterdesign commands.
The commands appear but when selected - the error message comes up. (is this normal or is there some other issue).
Troy
Message 4 of 9
TWJ13
in reply to: TWJ13
In my previous response I mentioned the message that I got when opening a raster file
This was incorrect. (I've had a chance to check the exact messege)
It reads:
"AeciRemUi51.arx cannot find a dll or other file that it needs"
This occurs after the raster file has opened - when i try to select
a raster command.
Any idea how to correct this?
Troy
Message 5 of 9
in reply to: TWJ13
You are more than likely missing a path statement in Acad.
Search your system for that missing file, then add that path to AutoCAD
thru Tools > Options > Files tab > Support File Search Path
After that, RD should start when you access one of the Image commands in
Acad.
Message 6 of 9
TWJ13
in reply to: TWJ13
Thanks Rowland.
I will see how this goes.
Troy
Message 7 of 9
TWJ13
in reply to: TWJ13
Rowland
Thanks so so so much.
That solved the problem - You've saved me a great deal of time - and headaches.
Much appreciated.
Troy
Thanks also to Matt - for your assistance with my initial Question.
Message 8 of 9
in reply to: TWJ13
glad I could help Troy.
Message 9 of 9
in reply to: TWJ13
Yes, the support file search path problem is common. It seems that some service packs end up removing the Raster paths.
Matt
wrote in message news:6396844@discussion.autodesk.com...
Rowland
Much appreciated.
Troy
”Boost
