AutoCAD Raster Design General
Distinguished Contributor
Message 11 of 17 (1,249 Views)
Re: raster design error unable to save
08-09-2010 02:39 PM in reply to: tggray
I also just started having this error.  Before today everything was fine, well, I was able to save images after editing them.  At least there is a work around.
Melody
Oh, and on top of this, today I am crashing like crazy.
Message 12 of 17 (1,247 Views)
08-09-2010 02:55 PM in reply to: msorensen
Well, I justed edited my .tif file and did the Save-As.  RD saved my scan.  Unfortunately the file size is larger than the original file :smileymad:  Not what I was looking for or expecting to get.  At least it looks a lot better.
Member
Message 13 of 17 (1,210 Views)
08-25-2010 07:08 AM in reply to: tggray
We installed AutoCAD 2011 and Raster Design 2011 on a Windows 7 (64) desktop.  We opened an AutoCAD drawing file, inserted an image file.  Used the raster design remove command to remove a part of the image.  Saved the image and drawing file and the typical error popped up telling us the image cannot be saved with the existin name and must be saved as a tmp name.
New AutoCAD, new Raster design.  What is the issue?  When will it be fixed or am I missing something here?  If anyone can correct me, I would greatly appreciate assistance.
lmcnulty@bepc.com
Distinguished Mentor
ampster
Message 14 of 17 (1,175 Views)
08-31-2010 06:39 AM in reply to: svend007
I do not know about the other versions besides 2009, but in our testing of this issue, we noticed that using the RD 2009 Save command does actually save the original image file even though that "cannot save" error msg pops up and it then creates an additional .tmp file.
Has anybody using either 2009, 2010 or 2011 noticed that the original file is being saved even though they are presented with that error msg?  You may just have to open up the original image file in MS Paint or something similar to determine it is actually being saved.
This has been a known issue since 2009 - and Adesk makes one user think they are escalating their attempt to fix this back in April of this year...where are the results of that "fix" they are working on...and will that fix be made to all versions of RD that are currently supported?
New Member
CarlNelson
Message 15 of 17 (1,064 Views)
09-25-2010 10:53 AM in reply to: msorensen
Yes, I noiticed that even though it comes up with the message about it being unable to save the tif and it does create the tmp, if I just delete the tmp it has saved the original anyway and is just fine... This is unfortunate because I believe it has caused much lost time for us to "discover" this for each person finding this error.
New Member
Message 16 of 17 (1,038 Views)
10-03-2010 04:02 PM in reply to: tggray
Hi Guys,
Just a thought... try checking the length of the path where the file is being saved to.
We have had this problem which was rectified by shortening the path name.
Not sure what the limit is but this worked.
Cheers,
Stretch.
Valued Contributor
Message 17 of 17 (492 Views)
06-29-2011 10:12 AM in reply to: tggray
Does anybody know if this has been fixed yet? I'm still on 2010 and this is a real pain. Seems like it should have been fixed by now if AD really put some priority on it. What about the newer versions? Thanks.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
New AutoCAD Raster Design Category!
The AutoCAD Raster Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
