AutoCAD Raster Design Forum
Message 1 of 1
105 Views, 0 Replies
parabola
Hi, In a geographic projection system, it would like to know if the plan of the Autodesk Map follows the forms of the parabolas of the latitudes and Longitudes. Example: If I to insert a geoimage in the Autodesk Map with Lat Long System with datum WGS84 the coordinates of "X" it must follow the parabola of the Latitudes that are curves and not straight lines as when it is in a designed System of projection. How can I get information of the consistent coordinates, therefore I need to extract random geographic coordinates and I'm worried. Dinhu
0 REPLIES 0
”Boost
