This depends on what you have to start with, the drafted accuracy of the
original, and distortion that has occurred in reproduction, and the
accuracy of what you want to end up with.
RD does have some semi-automatic vectorization tools but they require
user guidance and intervention to operate accurately. Under the best
circumstances, however, you probably expect accuracy above what pure
tracing can supply.
For a property plan, as a surveyor, I would never trust raster
retracement - I would rebuild the boundary from the calls I see on the
scanned drawing. For contours, I could probably accept what was drawn
but I still have to intervene to assign elevations to the contours as
they are traced.
For an architectural plan, blindly tracing the lines will most likely
not get them parallel and/or perpendicular.
In all of the above, you probably want some layer discrimination among
the various entities you are creating - again, this requires some user
intervention.
I have found over the years, that totally, or even semi-automatic,
overtracing produces a product that usually requires more touch up and
time than drawing it so I generally use the image as a guide and build
new entities using the best information available on the image. Using
raster snaps is a great aid, as is line following under specific
circumstances. RD also has great ability to massage the image to remove
bias and despeckle background noise.
Perhaps a description of the drawn objects and the level of accuracy you
seek would help.
Autotracing a sketch of a Barbie doll house is quite different than
doing the same operation on a drawing of a mechanical part or
subdivision plan.
Karl Fuls PLS
Autocad AEC Training and Consulting
Autodesk Discussion Group Facilitator
office-user wrote:
> Hello to the newsgroup.
> Working on Raster Design 2004. I have a scaned image of a drawing and i
> 'd like to converted to vector lines. As far as i know i can't select a
> window and converted everything in it to vector lines. Correct? Which is
> the fastest way to convert the whole image to vector?
> Thanks in advance.
