Did you send a crask report to Autodesk?
Are you doing a "quick" insert, or you transforming the image in some
way?
Since many MrSidds insert correctly, it may be the particular image
you are inserting.
On Mon, 17 May 2004 15:22:41 GMT, KASIKI13
wrote:
>Raster Design 2005 crashes anytime I try to insert a MrSid. I get the following error. FATAL ERROR: Unhandled Access Violation Reading 0xf9f3000 Exception at fc803f8h. Anyone know of a solution?
Phil Daley
