Hello, I am using AutoCAD Raster Design 2014.
I have an issue with the touchup command. After having AutoCAD open for a couple hours the touchup command quits working. I can start the command but, when I click to remove or add raster, the box disappears and I am no longer in the command. This happens every couple hours (sometimes less than an hour) and the only way I have found to fix it is exit and reopen AutoCAD.
