I've just installed this, and found that none of the tools in the Raster Tools tab work. All fail with a missind DLL (or other file that is needed) error.
The image in the attached screensot has been inserted as a reference, with ATTACH.
OS: Windows 7-64
Any ideeas?
Solved by Daniel248. Go to Solution.
No migration here. Setting Vanilla current did not work.
I've looked in the loaded apps list and aeciibui57.arx was not loaded. When I tried to loaded manually it failed.
(screenshot attached)
I guess it's time to log a support request for this.
Thanks benh
I had a similar problem if you try and add the two raster paths to support files (Shown on the attached file) you may find that solves your problem.
Regards
Paul
Spent many minutes/hours trying to get vanilla AutoCAD to load Raster on demand with no solution. I remember this happening with past versions as well. This is the first time I've found a solution that WORKED!
Thank you so much for the help.
Brian
