AutoCAD Raster Design Forum
Raster design 2014 - cannot find DLL
7 REPLIES 7
Message 1 of 8
Daniel248
6652 Views, 7 Replies
I've just installed this, and found that none of the tools in the  Raster Tools tab work. All fail with a missind DLL (or other file that is needed) error.
The image in the attached screensot has been inserted as a reference, with ATTACH.
OS: Windows 7-64
Any ideeas?
7 REPLIES 7
Message 2 of 8
benh
in reply to: Daniel248
Same here
Message 3 of 8
benh
Did you migrate settings from an earlier install? I searched some more and found a post from a few years ago where someone changed back to the vanilla user profile and it worked. I just did the same and can confirm success. l Let me know if it works for you.
Message 4 of 8
Daniel248
No migration here. Setting Vanilla current did not work.
I've looked in the loaded apps list and  aeciibui57.arx  was not loaded. When I tried to loaded manually it failed.
(screenshot attached)
I guess it's time to log a support request for this.
Thanks benh
Message 5 of 8
Cadguy68
I had a similar problem if you try and add the two raster paths to support files (Shown on the attached file) you may find that solves your problem.
Regards
Paul
Message 6 of 8
Daniel248
Adding the two raster paths to support files worked.
Thank you cadguy68
Message 7 of 8
snakerancher
in reply to: Cadguy68
Spent many minutes/hours trying to get vanilla AutoCAD to load Raster on demand with no solution. I remember this happening with past versions as well. This is the first time I've found a solution that WORKED!
Thank you so much for the help.
Brian
Message 8 of 8
MariaManuela
Nice! Solve the the problem. Thanks
Asidek Consultant Specialist
www.asidek.es
”Boost
