I’m having a weird issue with the File Support Search Path and Raster 2011 and different profiles. When I launch Raster on a user machine it will not load menus.
That is because the search path in this particular profile is set to:
C:\users\<user name>\Appdata\Roaming…etc.
The only way to fix it is to switch to a profile that has the path set to:
C:\users\Administrator\Appdata\Roaming…etc.
That is where the AecCo.cuix menu is installed.
I could have sworn it was the user’s roamable root that is configured for the menu. Is the Administrator's path correct? If not, how do I set it correctly?
