From Isaac Rodriguez, answering my post:
"If you are using a network deployment of RD2004 to install the application,
it may happen that RD2004 has not been correctly binded to LDT. We have a
problem in the network installer of RD2004 where if the user unselects some
of the desktops available in the Select Features dialog, the installer does
not respect the options selected. You can try to create a new deployment
accepting all the defaults and not disabling any of the desktops available.
That will ensure that every desktop present will be available for binding
and your scenario should work.
If accepting all the defaults fixes your problem, and you still need to
create a deployment that only binds to LDT and Map, let me know, and I will
work out something with the support people so that we can fix your problem.
Thanks for reding.
Isaac Rodriguez
Software Engineer - Raster Design
Autodesk.
"Brendan McKee" wrote in message
news:4061d205$1_2@newsprd01...
> Using network deployments of Land Desktop 2004, Civil Design 2004 and
Raster
> Design 2004 I am having trouble getting RD to start. LDD and CD work
> correctly, but the RD install does not work correctly. In past versions,
> sycronizing RD was not automatic and required the menu to be loaded
manually
> the first time it was used. This did not work with the RD 2004.
> We normally run RD from LDD or Land Enabled Map rather than directly from
an
> RD desktop icon. In this install there is no RD icon on the desktop or in
> the program menu. Only the Borrow License utility was installed in the
> program menu folder. The network installation log shows a successful
> installation.
> I could try manually loading the proper *.arx file to get commands running
> in LDD, but I would prefer to have the installation work a little more
> automatic since it will be deployed to 20-25 computers.
> The computer with the 2004 installs also has the 2003 versions of
LDD/CD&RD
> installed. I have been using the provided batch files to modify the
> registry settings before running either series of products.
> Thanks for any help anyone can offer,
> Brendan
