AutoCAD Raster Design Forum
OCR Problems in RasterDesign 2010
4 REPLIES 4
brickmanFW
858 Views, 4 Replies
I am trying to use the OCR and always get the message "Text recognition operation failed to return a valid result."
Any Ideas?
4 REPLIES 4
in reply to: brickmanFW
if you press the Details -button, what does it say?
/Petri
brickmanFW
This is all I get.
SmithG_NZ
I recall something in the ReadMe about OCR on Vista 64 (and I presume all 64 bit MSOS). What OS you using?
pleru
How have you resolve your problem ? Because i have the same error with the french version of Raster Design 2011 under windows xp pro 32bit SP3 within AutoCAD Mechanical 2011 SP3
when i use the command IRECTEXT
I have no message on the command line of AutoCAD but i have a dialog box with the error message:
"La reconnaissance de texte n'a pas donné de résultat correct."
"Pour plus de détils, cliquez sur le bouton Détails"
and the details is:    "Une erreur inconnue s'est produite"
see the error message on the screen capture attached.
Best regards,
Philippe
”Boost
