AutoCAD Raster Design Forum
Missing dll
4 REPLIES 4
bpittman
4258 Views, 4 Replies
Missing dll
When trying to run Raster Design, I get the following error message:
"This application has failed to start because acdb17.dll was not found. Re-installing the application may fix this problem".
But a reinstall did not fix this problem.
Any thoughts would be appreciated.
4 REPLIES 4
in reply to: bpittman
There is a hotfix for this.
http://images.autodesk.com/adsk/files/open_save_close_hotfix.html
Bill
wrote in message
news:6317485@discussion.autodesk.com...
bpittman
thanks, but that's not the fix, I don't think.
First, its for 2009 products. I'm using 2010.
Secondly, it refers to replacing the acdb17.dll. I do not have one to replace.
Nor is there one on other installations on machines in this office.
update. I removed raster design from the machine, and reinstalled it.
This time I'm getting a message about a different dll missing. ac1st.dll
help? Edited by: bpittman@opkansas.org on Jan 13, 2010 4:05 PM
abenson
AutoCAD & Raster Design 2010
You may have migrated the previous version settings when opening AutoCAD 2010 for the first time. If you did, then AutoCAD is looking for 2008 or 2009 acdb17.dll file; AutoCAD 2010 filename is acdb18.dll.
To correct this problem:
1. Change your current AutoCAD profile to Unnamed or Initial Setup Profile under options => Profiles tab. If that doesn't work, then you may also need to use someone else profile who didn't accept the previous version settings.
2. Close AutoCAD
3. Open Raster Design 2010
DouglasLauritsen
AutoCAD Raster design 2010 may be finding resources from AutoCAD or Raster Design 2007, 2008, or 2009. This Technical Solution was written for the majority of side-by-side users with 2009 and 2010 installed. These instructions can also be translated for 2007 and 2008. The goal is to get the Program Files\<Raster Design> paths out of the Windows PATH statement and in to the host AutoCAD's Support Files Search Path.
Douglas Lauritsen, Autodesk Product Support
We appreciate your quick feedback on this forum!
Douglas Lauritsen
Support Specialist
Product Support
”Boost
