AutoCAD Raster Design Forum
Missing IINSERT Command
5 REPLIES 5
FBP_IT
1639 Views, 5 Replies
installed raster 2014.   raster tab, insert, gives error
c:\program files\autodesk\autocad raster design 2014\aeciibui57.arx cannot find a dll or other file that it needs.
already changed the current user reg keys but still not working.
what gives?
5 REPLIES 5
FBP_IT
in reply to: FBP_IT
windows 7 64 bit by the way.
in reply to: FBP_IT
is that the only command not working?
dwalkerie
in reply to: FBP_IT
Has anyone figured this out - I have the same problem.  It's not just the raster tools "iinsert" command but all the raster tools.  The directories for raster tools and path exists for the command back to the aeciibui57.arx file but it's saying it can't find a needed dll file.
in reply to: FBP_IT
Check to see if your Raster Design path is mapped in the Working Support File Search Path. Go to Options, Files tab, Working Support File Search Path, browse to Raster Design and add, also add RD help. This worked for me.
dwalkerie
Thanks for the response. I came across a Autodesk Knowledge base article concerning this problem. It said to basically uninstall / reinstall everything. I had just
loaded it so it was no loss starting over. Everything is working fine with the new install.
”Boost
