On Thu, 2 Feb 2006 12:54:14 +0000, danay <> wrote:
>I Insert a Raster file ((JPG) who was rubber sheet to it's coordinate By Raster Design method and was export by raster design tools with burn rotation and world file) By Map>Image >Insert
>The raster's was out of place by 800 meters
>The JGW has a non uniform X Y Scale.
>I need that the raster's will be insert in it place in AutoCAD Map 2002. as the same place it is in the Raster Design.
>Do the methods of INSERT in ACMAP 2002 is different from ACMAP 2002 Raster Design and what are the differences in the Calculation?
Map doesn't know how to Rubber Sheet. Inserting a differential X-Y
image in Map will be different than inserting that same image with
Raster Design.
Phil Daley
