When running the IVMERGE command to merge Vector to Raster with any Solid fill in a Vector file using RD 2004 on ACAD 2004SP0, or SP1A it crashes. A Dialog box with AutoCAD Error Aborting, stating Fatal Error: Unhanded Access Violation Reading 0x0000 Exception at 2fe48aah appears.
The IVMERGE command on the same file in AutoCAD 2002 with Raster Design 3 works perfect.
I have tried this on several machines, with the same results, and this is preventing me from completing our upgrade from 2002 to 2004.
Have other people seen this problem?
Thanks in Advance
Mike Ostrouch
>AutoCAD Support
This is a known bug in 2004 and will be fixed in an upcoming release.
Phil Daley
